Eh, wot ye say, some one call ?
Still here, only fix and tune my own saws generally though. Whats the situation nemcc ?
5 hours ago, Khriss said:
Member on here called Bmp ? If he is Stihl around . K
Was that "Stihl" you being droll or just a shyte speller:hmmmm2:;)
Very good if it was the former!!
Teasing the spelling Nazis on here...or just my phone crap auto corrept. K
It's a 500i.  Lost a clutch spring and fear part of it may have gone somewhere it shouldn't as saw will start but then stop. Bugger
I really cannot see any route a clutch spring could take to stop the engine running other than jamming something in the chain case area.
As with all these saws that run for a little lime then stop my first look would be through the exhaust port to look and the piston and rings, if they are good then we can start with swapping the spark plug and move on from there.
If it was locking the drum to the clutch somehow or interfering with the oiler arm then it may stop the saw at low revs. These engines don't make much power at idle speeds and a slight impingement will stall the engine.
Just a case of removing the drum and clutch, replacing the spring, clearing the broken parts, reassemble and test.
