Do any of you dry logs in containers made of Weldmesh Panels?
cessna
On 27/05/2022 at 14:36, doobin said:
There are scaffold poles driven down the sides for support, which also support a scaffold tin roof easily once filled.
Method in the madness 😉
I used 4 of them a few year back when i had filled all my IBC,s fastened all 4 corners of panels with clamps and zip tied 3x2 uprights about every 2ft on the inside, put pallets on floor and when it was half full put another layer of pallets in and it worked fine, bulged a bit but not much,,
18 hours ago, doobin said:
Done three, all still standing.
Really useful to be able to just clip a roof over the top for the client too.
what did you use for the roof, another panel on the top and then some sheets onto that?
i did a couple of these a while back and need to stick a roof over them
No, if you space the side poles right you can clip poles between them and then the roof sheets clip to this with the scaffold roof clips.
