For years I have wanted to get a better system for cleaning logs ready for milling.  I like the idea of using an airblow gun fed from a compressor, but I have really no idea what type of gun and nozzle to get.  We already have a simple PCL one which is OK, but can anyone make a better suggestion?
There are loads on the market but what type is going to work best for removing mud and stones from bark?
I know a water pressure washer would probably be more effective but I really don't want all that muddy water sloshing around.
Thank you in advance to my fellow Arbtalker's!
100 cfm road compressor with 3/4 galvanised pipe, stop end drilled with 6mm hole and valve at the other should do the job, doubt you will move much with a pcl fitted lance should remove the bark!
Edited by dumper
Spelling
Mmmm thank you for the suggestion, might be a little overkill!
If you are going to do it go big can’t see a little blow gun moving ground in stones or mud
Well, my little 6CFM compressor does it reasonably, but I think I can probably improve with a bit more power and maybe a different gun.
1 hour ago, Watercourse management said:
just in the process of building a debarker for mine.
Well of course that is another option.  I think my mill will take a debarker, I haven't looked into the cost of that.
