Walnut
Bennovet
Challenge for the summer.. what to do with this bit of walnut.. 900mm wide, but my will will only do 790mm..
I have milled a bit from higher up tree last year. Was very nice. The lowest part coming out ground was a lot wider still but also had some rot.
This looks very promising at 3m long..20220201_172523.jpeg20220201_162802.jpeg
Keep us posted bud !
Get a bigger mill so you can mill the full width you need. :thumbup1:
What saw  / mill do you use, your 790mm Is about the max for a 36" Alaskan mill?
I use an old Stihl 076, loads of torque, low revving but thirsty. On .404 ripping chain. Indeed 36" Chilaskan.. was fine till now.
Options: reduce walnut sides and cut 790mm wide slabs.. I dont have bigger trees myself anyway. (Milled a 30" oak tidy)
If I go bigger.. either on same saw with skip chain? Additional oiler, slow, etc.
Knowing me, i will want a bigger saw...(Got a 241 and 462 as cutting saws)
Would like a bandsaw mill really, also have 2 trailer loads of 18" larch to mill for cladding, was meant to take to a local miller (woodmizer LT40).
What entry level mill would suit my (hobby) needs. Was hoping to have 3phase power this summer but prob safer to get petrol/diesel
You can get longer mill sections from rob D for the mill, getting you up to a 48” bar with those. For not much money. You won’t need an extra oiler with the 076 I wouldn’t have thought. Probably don’t need skip chain on a 46” bar IMHO. Longer yes but not 46”.
You can get a 46” bar for the mill and get through lots more wood or go even bigger.
Check out the website and see what options you like.
Before it got stolen I used to run an 076 with a 47" Duromatic (hard nosed) bar. With the low revs it didn't overheat, although I used to dribble a bit of oil on the end of it from time to time if I was working it really hard. That was running standard .404" ripping chain.
Alec
Like the look of the extension set for my mill, easy fix. Then the bar.. lo pro only goes on 3/8 chain? Which means a new sprocket to go with it. But might be cheaper chains and lot less sawdust?!
Rollomatic or Duromatic? Currently have 36" duromatic.
I dont have the winch kit but always but the log on a fair angle so milling downhill[emoji6]
Spend 300,- on upgrade.. makes any bandsaw mill look very expensive..
