Newbie here.
We live on a Northumberland hill farm and we got hit pretty bad by Storm Arwen (11 days with no electricity!). We're still cleaning up and I am processing several Scots pines that were blown over.
Using the general farm saw - a relatively recent Husky 135 with a 14" bar and the usual Oregon general purpose blades. I am replacing blades every hour or so and re sharpening using my Granberg so the angles are correct.
Now with the upper branch wood, this set up works fine, however, I am really struggling with lower trunk. Scots pine is pretty tough stuff when green.
Can anyone suggest a full chisel blade that would fit this saw and where I could get a supply in the UK? Alternatively, any recommendations for a better blade for cutting dense green wood would be very welcome.
cheers in advance
Buttered Scones
Before you buy check what bar you have on there. It will say on the bar what chain it runs, you'd expect it to say 14" 3/8 0.50 and some number of drive links (52dl maybe). Let us know what's on there.
24 minutes ago, Buttered Scones said:
Newbie here.
cheers in advance
Buttered Scones
I think there’s something else going on here. You shouldn’t be changing chains every hour unless you are being a bit clumsy with the saw and hitting the ground often.
i wouldn’t have said Scots pine was particularly tough to cut and oregon chain is certainly up to the task.
  • Like 8
31 minutes ago, Buttered Scones said:
Newbie here.
cheers in advance
Buttered Scones
Hi and welcome, you'll be able to find any chain [ not blade ] and any sharpening advice you need on this site.
Maybe you need to check the depth gauges / rakers to see if you're  getting the right depth of cut ?
As said above Oregon chain should be fine.
Chainsawbars - Largest selection of chainsaw guide bars and chainsaw chain for Stihl, Husqvarna, Echo and Dolmar...
Edited by Macpherson
Part of the reason you struggle with " the lower trunk " is its a 35cc " home owner saw " . Keeping it sharp and taking down the rakers every third sharpen will help . Keeping it out of the dirt will help . A bigger saw will help !
Edited by Stubby
Wait 'till you try splitting it. The knotty stuff is some of the toughest wood I've ever tried to split!
I have a similar sizes saw and it seemed to cope fine on Scots, it was running the 91VXL chain. I try not to take the depth gauges down too far if I'm logging up something big.
Is your chain definitely getting blunt? I find the bar can pinch slightly in bigger wood, knocking in a plastic wedge in the top of a cut when half way through a log helps.
I've found the chain can get blunt when processing ash that's been down a while, I just take a hand file with me and give it a quick sharpen every so often. I also thought full chisel chains are more prone to blunting.
I'll have you know the 135 is a massive 41cc Stubby.
As for the full chisel chains they will not stay sharp any longer than the semi chisel in my experience. I got a couple for the 135 from Northern Arb supplies.
Well yes . A dull chain is a dull chain whatever cutter type . Semi is supposed to take damage a bit better that full . However all my saws have full because I feel it cuts faster . Just keep them out of the dirt . I wrongly assumed the capacity of a 135 . Sorry . Its not a pro saw though ....
Edited by Stubby
You're right there. Full chisel does cut quicker. I only used semi on big saws as they need sharpening less then.
