Advise on 1st Chainsaw for home use
Steven1210
I measure in a jug i got that gives all mixes on side but now got the Stihl litre bottle that has bit at top to measure.
Just plain litre plastic bottles just F'in leak as don't seal right! as cut bit off to open but as soft there isn't much for cap to bite/seal on edge so kept weeping!
Put oil in can then 5 litres of Super give it a shake also after then put into fuel can when it's low always keep it that way so not making mistakes or mix wrong if stick to 5 litres
I mix small amounts as I found it could take me about a year to go through 5 litres.  I bought a metal 2.5 litre bottle and user that, and use a small measuring cup to measure the 63ml of oil (40:1).  I used a large syringe for a while, and use a small one to add the few ml of stabilizer.  I still find I often have a litre or so around for 6+ months as I cut very little over the winter,  as now, I mixed 2.5 litres in late August/early September and ran 3 tanks through the new EA 4300, the remaining litre could be sat until April.  It's not been a problem, sealed metal can, stabilizer and good oil, plus super grade petrol, it keeps ok, but I've just bought a 1 litre bottle with the intention of using that when I need a little mix late summer.
Also, mark the measuring cup or syringe at the regular amount and it's pretty simple.... Not fool proof, but pretty close.
Edited by neiln
2 minutes ago, neiln said:
I mix small amounts as I found it could take me about a year to go through 5 litres.  I bought a metal 2.5 litre bottle and user that, and use a small measuring cup too measure the 63ml of oil (40:1).  I used a large syringe for a while, and use a small one to add the few ml of stabilizer.  I still find I often have a litre or so around for 6+ months as I cut very little over the winter, so as now, I mixed 2.5 litres in late August/early September and ran 3 tanks through the new EA 4300, the remaining litre could be sat until April.  It's not been a problem, sealed metal can, stabilizer and good oil, plus super grade petrol, it keeps ok, but I've just bought a 1 litre bottle with the intention of using that when I need a little mix late summer.
It all sounds very complex . I have a 2T bottle marked off in wide graduations . One graduation is for 5lters of fuel .  5 liter combi can , pour in one graduation , top up with  petrol/aspen4 or whatever shake and jobs a goodun .
What's complex?  Open oil bottle, fill measuring cup to clearly marked spot, add to can filled with petrol, cap and shake?  I mean stubby we've never met, but you seem to know one end of a saw from the other (don't hold the one with teeth!) So I think you'd find it quite forward!  I'd say foolproof, but I don't want to suggest you're a fool.
All in all, it's easier than driving to catford to visit jonsey and buy some aspen, and much cheaper.
Same as mine but without " fill measuring cap " 🙂
Hi again guys
Silly one again.  So its a no go on the trouser front, and I spotted this lot helmet with face and ear protection, husqvana pants and gloves.
Husqvarna Chainsaw Protective Kit - World of Power
It this acceptable for a newbie, protection wise?
PS got the aspen fuel today for the saw, no messing with measuring now😃
