15 minutes ago, Mark Bolam said:
Kirklands made a new body for me but still on original tipping gear.
I THINK from VFS, but can’t remember 100%.
Where would that valve be @eggsarascal?
I had a similar issue , it turned out to be the bearing at the bottom of the ram had seized. It's a bad design . Lots if wd40 later and it freed itself
You are looking for something like this, the valve is on the opposite end.
Surely if the bearing had seized it wouldn’t return at all though?
Would grease all moving parts first and see.
Use a couple of old farm trailers in the past that would take there time dropping greased pins and speeded job up no end.
Nope.
I doubt it’s grease Paul, ram drops quick enough every shunt.
Checked the sensor switches that tell when the body is fully lowered and they seem to be working fine.
