You can't own a patent for a hex file. Well, I suppose you could, but you'd have a devil of a job enforcing it.
You really know you’re stuff don’t you?
[emoji848]
One thing that could be clever about this system is that the file will sit at the right height - so you need not worry about causing the cutter to slope backwards - or to be 'beaked' and be too aggressive.
Actually just had a 'light bulb' moment about chain sharpening! Too good to share will see if it is possible first ;)
Stihl are well capable of enforcing their patents if they feel like doing so. And as said - I can't find any hex shaped files on the net - so it would be unique.
You can buy files similar to that already . Files for sharpening square ground chain . You are supposed to file from the outside inwards as opposed to inside outwards though .  They are hexagon , double bevel and a goofy .
With respect, just because you can't find something on the net, doesn't mean it could be granted a patent. I'd go as far as to say that a patent for a hex file probably wouldn't be granted (if the hex was the only point of differentiation).
1 hour ago, openspaceman said:
Do you know why?
I think it just gives a keener edge . You don't get any burrs that need knocking off like you can with a round file going from the inside to the outer .
