Well, I pressed out the bearings this morning - so simple, just use an appropriate size socket and hold the roller on the jaws of an open vice so there is a void for the bearing to go into; and whack the socket with a hammer.  Can't believe I didn't try this years ago.  Have ordered replacement bearings online at a cost of £4 each and it takes two per roller.  Pressing them in will be a sinch so happy days and thank you for the helpful suggestions.
Arbtalk comes up trumps again.
Good job.
4 hours ago, trigger_andy said:
Logosol Mills use the same Rollers, so if youre ever needing to change them out (not just the bearings) then drop them a bell, prompt delivery as well
Ah thanks Andy.  It turns out the Woodmizer ones were too small internal diameter, but for a while now I will be fine once I put the new bearings in.
Done Like most bearings I have to change. Ie the stihl strimmer head. And I just brought the correct bearings from a bearing supplier. At a 1/4 of the price of stihl
i'm pleased it worked out for you 😉
  • 4 weeks later...
