echo 2511 chain brake
stewmo
Looking for a diagnosis....
When the chain brake is on, and I squeeze the trigger without taking it off, the chain does actually move some....it doesn't feel dangerous but at the same time I would rather it didn't do that! So I'm thinking the brake band is getting old maybe? Could it be anything else?
Thanks in advance.....stew
Yeah mine does that, just a worn band is all, 20 min job to replace if you can be arsed.
We sell a lot of brake bands so I presume they wear fairly quickly. Make sure you take a couple of pics of the setup as there is a little plastic square washer that can get missed and the brake band doesn't come with the small roll pin, easy to displace this item.
Thanks Mark [emoji106]
Think I have only ever bought 2 in my whole life . But the I don't use the brake 😁
