Log ID
trigger_andy
5 minutes ago, trigger_andy said:
I’ve milled plenty DF. I’m not convinced it’s DF either. Never had DF wrack bands so fast.
Just as well you’re using an idiot proof fence post maker. Much more forgiving than a Bandsaw. Suits you down to the ground and on the slooooow long cuts you can join the window licking queue.
Be straight with the guy and just tell him you cannot do the job as machine is not up to it. Simple as that Andrew no if or buts. He can take it to a proper miller then. 🤙
Well that rules you out Legless. Unless he’s needing 3” fence posts I suppose?
6 hours ago, topchippyles said:
Fence post -fence post-fence post-fence post is that all you can say.
It’s all you can make now you’ve bottled and sold your bandsaw and bought.......yip
a fence post maker.
Downgrading seems to be a recurring theme in your life.
Douglas fir for sure and you’ll find it particularly hard on blades when freshly felled, leave it sat for a year and it’s fine. Great timber actually, have found many customers prefer it to Larch. Also, turn water / whatever lube you’re using up to the max flow
Well, yes, was my first thought on a burnt band- but then, wot the hell do i know abt milling  😆 K
What does it smell like? Douglas seems to have a very characteristic citrussy smell. Even a bit marmaladey, like a very old dry Riesling I once drank in fact - burnt marmalade, in fact
but I was ver ver drunk at the time of course
