661 - bar length?
Dilz
5 minutes ago, topchippyles said:
Speak with him regular but just wondered did you guys know as we are online
Cheers Les,
 In that case I apologise. I am no help. I would be interested in your findings as I just use Lo-Pro.
Guys what is the difference between the lo-pro and protop bars ? Looking at getting a couple of new bars and just wondered what you guys prefer as your favourite for milling. I currently use a 36" lo pro GB
It’s the brand. GB pro top.
The lopro bars sold by rob are GB pro top. The orange coloured bars.
Yep as above - same company but different brand.
The GB ProTop are professional single piece steel bars [ie. non laminated] and are thicker - designed for all round use. The lo pro bars are milling only [although some use them for cross cutting as well].
Spiel on lo pro is all in the description here:
SNHS42-50WR 42"[107cm] GB Lo Pro Milling Bar 3/8 Lo Pro .050 137 drive links. Cuts a thinner kerf when milling timber...
  • Thanks 2
GB bars are lovely bars, I'm slowly going over to them on all our saws as they ware out.
Yep the ProTop bars are very underrated - mainly I think because they don't look as flashy as the Japanese bars or they are not as well known as Cannon. But they are solid, easy to maintain bars with a better price tag than the others.
I notice all the panther milling kits on the website that are 3/8 are low pro.  is this the preferred set up?  Right now  for a 661 seems like folk are saying that something like the the 40" mill with 36" bar would be a way to go that wouldn't be too much stress on the machine or??
It is for most - not for some.
If you read the info here https://www.chainsawbars.co.uk/product/snhs42-50wr-42107cm-gb-lo-pro-milling-bar-3-8-lo-pro-050-137-drive-links-cuts-a-thinner-kerf-when-milling-timber-than-standard-chain/
Good stuff! It sounds like for the 661 lo pro is probably the way to go - might chance it and go for 42" bar..can always mill small stuff with a bigger bar but probably harder to mill bigger stuff with a smaller bar??
You can't mill bigger stuff with too small a bar - but yep you can do smaller stuff with a bigger bar.
That’s it in a nutshell, just ordered another mate for a 461.
