Just now, Tippin Alaybye said:
Looking to cut some featheredge panels on my woodlander.
Any tips?
I was thinking once the section is square just putting a suitably thick batten on one edge to give the angle??
Ive been looking at this as well lately as Ive been asked if I could supply 300 lengths of featheredge. Really need to make a jig like the one in the link below.
That jig in the video is very simular to what a mate of mine made but his was not operated with hydraulics it was with 2 pieces of threaded bar and a nut gun, worked ok but was slow as he had to go and either slacken it off or tighten it up every cut, hence now he just cuts 125 x 10 mm boards for his fencing,
1 hour ago, gobbypunk said:
Woodland Mills sell a jig for their mills but its like £500
Thats a lot of wetherfegde boards from Jewsons.... Which reminds me  😑 K
If you're just needing the same degree of angle then surely there is a simple method of clicking up and down from that angle?
any Heath Robinson ideas that doesnt involve 500 notes? ive just spent nearly a grand on accessories. Any advances on my batten idea?
BTW, i just looked up Heath Robinson. he did the opposite to how we use his name. Elaborate contraptions to do a simple task.
the same Wikipedia page said "throwing money at a problem was to Trigger it"
Edited by Tippin Alaybye
  • Sad 1
You need to speculate to accumulate.
Can you imagine how slow it would lifting the Cant every second pass to lift the Cant off and put a batten down then replace the Cant. Not to mention buggering your back. For the sake of an extra £500 for what looks like a very effective system verses a lifetime of a buggered back you'll have wished you spend the £500.
Plus the money to be made off of featheredge is quite substantial, the initial outlay of £500 verses the production rate of the Woodlands kit would see it pay itself on the first or second order.
And coming from a man thats just spunked a bag of sand on shiny new toys when I bought the same Grinder with an outlay of about £200 and most of its brand new now. You can edit Wiki yourself, change the name to your own, you deserve it. :D
