T540ixp advice
Heywoodwood
Anyone know if the T540ixp can run a Sugihara bar?
I brought the unit with bar and chain and also a Sugihara bar using Honey Brothers bar and chain finder. Or though on the Sugihara bar case it doesn’t mention the T540ixp. Is it useless or has anyone running the set up? Help would be much appreciated!
I have a feeling its the micro pitch chain and cant use the bar. I have tried fitting it with no luck.
Husqvarna T540i XP is our most powerful battery-powered top-handle chainsaw, ... X-Precision Laminated bar .325” mini PIXEL 1.1mm Small bar mount.
If it fits the criteria any manufacturer's bar should work, is it the correct pitch ? Contact chainsawbars and ask what you should have.
2 hours ago, bigtreedon said:
2 hours ago, stewmo said:
I was wondering about panther bars and if anyone knows if they can be put on the t540i xp so can use the 1/4 pitch chain....anyone?
Yes u can
Thanks Don....Do you know if it makes a significant difference to the stock bar and chain?
