Felled some sycamore in November, split within a day or two,
then in a pile out on drive for 3 weeks,
(while sorted a space to store it and buy a log store!)
then in a 1.8meter wide/1.6metre tall/60cm deep corrugated-roofed and metal-sheet sided log store out front.
But now it’s all mouldy
and getting worse every day
and even made some ash mouldy too
(with green fuzzy mould spots all over it too).
Why has this happened?..
Did I leave it too long on the drive..?
Is it poor ventilation because it’s actually in a corner outside and the sides are not open?
Or is it because it’s sycamore?
(I have an idea it’s because it’s sycamore but I hold be great to hear your thoughts and experience,
as you can probably tell I’m a newbie!)
cheers
Edited by LumberJack1984
I think poor airflow makes sense;
as it happened in a nook area on my property and in the corner bit out front of the house too.
Standing in these areas now with these 30mph winds we’ve got in the East Midlands, there is not great air flow.
AND they were too near the front of the house (about 10cm away from it) and too near fence too (fence was about 10cm away from back of other wood store).
Really helpful as makes most sense.
Thanks loads!
9 minutes ago, LumberJack1984 said:
Ash next time too to help with a much lower water content even when start off green!
Not a lot in difference of green moisture content between ash and sycamore.
Prejudice against sycamore because it is non native is a bit over rated IMO
Mould is simply living off the more volatile solids in the wood until it dries below 20% and not much to worry about, airflow is the answer.
