Electric chainsaw sharpener
Bluebird
I have a cheapo bought in Lidl and it has worked well for a couple of years. However recently after a few minutes use the grinding wheel makes an abnormal vibrating sound. I have cleaned everything out, turned wheel around but no change. This is the second wheel I have used and there appears plenty of life left in it. Any advice will be appreciated.
3 hours ago, spudulike said:
Hold the centre boss and move up and down to see if there is play in the output bearing. Make sure the power is off!!
This is what I came here to say 😂
If you're lucky it'll be running on sealed bearings and they'll be easy to get at. Whether or not £10-15 on decent bearings and potentially an hour or twos fiddling and testing is economical compared to buying another one depends on how much they are new though.
