Question
I am looking to purchase a property that has a TPO in the grounds. I am told many enquiries have fallen flat due the TPO which relates to a huge Beech which appear to be less than 3ft from a wall with roots protruding beneath the proeprty. What is the procedure for having the TPO removed and if approved whom would be responsible for removing the tree?
7 answers to this question
  • 0
You would need to submit an application to your local (to the tree) planning authority. You will need to provide evidence (probably a tree survey by a Suitably qualified person) that the tree is causing structural damage
Edited by Will C
  • 0
Now this is total guess work, but judging from the adjacent buildings, and the brick styles, I'd say that the tree was there first, ie the house is a new build. If so, how in Heaven's name did anyone get permission to build the house? Could be wrong, of course, often am.
Edited by Peter 1955
  • 0
Was thinking the same . Lovely  tree though .
Edited by Stubby
  • 0
Thanks for your advice
