John Hancock
Video - Access a Tree Using a Rope and Harness - Two Rope System
Good morning,
I realise the subject has been done to death and has been much debated in the past but this video has been sat in my Youtube account not going anywhere so I thought I'd share it.
Access a Tree Using a Rope and Harness - Two Rope System - We decided to make a series of videos as a learning resource for our students (mainly the new ones), starting with the basics, preparing them for assessment. Interestingly, when teaching and instructing new students, they really don't have a problem with using the two-rope system, they feel more secure and it aids better positioning throughout the tree.
The next video will be: Installing a cambium-saver from the ground  and undergoing aerial rescue in an open-grown tree.
Share this post
Link to post
John, thank you for sharing, that was an excellent video, the close up and context shots worked so well.
As a matter of interest, and this is a learning point for me (and maybe others), I note the methodology employed a strop, i.e. a 3rd point of connection, at change-overs...is this a C&G assessment requirement?
Also, and I know this will probably never "catch-on", but when you refer to "load bearing anchors" the term now used (because IRATA use it and HSE liked/expected it) is "unquestionably reliable" :/ (semantics)
Thanks again, I haven't climbed for many years but that video inspired me to consider it ;) ...maybe because of the weather.
Regards,
Paul
Share this post
Link to post
Well done John, that was probably the most efficient demonstration of 2 rope climbing to the new guidelines.
I can't help but feel sorry for you guys as lecturers and the students having to conform to these regs.
Good video, albeit of IMO a clumsy and inefficient way to climb a tree.
  • Like 6
Share this post
Link to post
Job well done Jon. Great video. Unless you mind will use it for training here too . I've been meaning to do similar for years - never done it. So very well done and thank you. All clear and correct!
Share this post
Link to post
Regards,
Paul
Hi Paul,
Thanks for your feedback :-)
C&G are due to update their assessors imminently (they may already have - it takes a while for information to filter through to the colleges). Once the update is received then modifications can be made. From a teaching / instructing point of view, it's no bad thing to have two attachment points in the tree while undertaking a changeover, particularly with new students.
'unquestionably reliable'.....bit of a mouthful isn't it!
Share this post
Link to post
Cheers Rich,
All credit to Ben Andrews for being an excellent instructor, I just stuck the GoPro on his head, wired him up with the microphone and off he went....and a little editing of course ;-)
Share this post
Link to post
That was a very smooth demonstration, what i do not understand is why we are not using techniques that IRATA have been working on for a good number of years. Personally i would rather use my duck on a back line in the same way i would when abseiling
WWW.UPANDUNDER.CO.UK
The S.Tec Duck-R is a back-up device in the style of the Petzl Shunt but in this case it works only on one rope and has been certified for use in work at height scenarios rather than as...
Will this be deemed acceptable?
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Tip site reviews
