8 hours ago, Mark armstrong said:
Aye a seen that mate I have a load of elm there but all 2" so won't need resawn that it's just oak and spalted beech I would of been cutting agen lately because a coustomer who dose van conversions only wanted 18mm tops was a shame wasting over 2" of 27 year air dried stuff plus if a could manage to mill my own logs tiny amount would save paying someone 450 a day if a get the mill I will get a forklift and a little tent kiln saves messing about with shipping am not the brightest when it comes to all that crap get stressed easy so everything I need in 1 place is what am thinking
How big is the stuff you intend on milling mark ? How wide and thick
Anything around a MTR wide and a mix of 2" and 3" but would resaw the 3" in half for the van conversion coustomer and finish with the router and if anyone else wanted skinny tables etc just a waste of good wood when it's a pile of shavings lads in the allotments love it for there hens but it's no good for me
Have you thought about a chainsaw mill setup like roughy uses.You do not seem to be looking  at milling volume and would you get the use out a big mill ? Plenty of options to think on.
Edited by topchippyles
Thought about it and thought about all the extra codine I would need to eat then never thought about it agen mate my back pain wakes is up a few times every night so something that dose the work for me is what I need mate it might work out a just buy a lorry load of logs mill them then not use the mill for a few MTH but least it's there if a do need it to resaw something or buy a log a can't resist lol as little wear and tear on my body is what a need mate lol
I totally get that mark 1 million percent.Its not easy to get a selected load of mixed logs in from the big operators so i wheal and deal and go part load with a couple of bigger buyers.Chris pearce who is the woodlands dealer buys in 25 ton so do a deal on the next load and i take a third which is plenty for me. Looking at a big batch of larch in the new year
I did a 2 day resawwing job for a joiner at the Chatham dockyards. He had a load of 80cm+- wide elm boards cut in the 90s that he wanted flattened and squared up. Its fine to do on a bandsaw but you need to use a lot of water and keep the feed speed right. A lot easier when you have electric feed. I used 4 standard woodmizer blades over the two days.
The problem is a lot of mill manufacturers are producing mills with large cutting capacities but with motors and components that aren't really up for milling max capacity all the time. A Woodlands hm130 claims a cutting capacity of 30 inches but has a 14hp engine whereas a woodmizer lt40 has a 28 inch capacity but uses either a 26hp petrol or a 35hp diesel engine. I have used Woodlands hm122, a lt40 and a lt20 so can only compare these bandsaw mills
Edited by Jamespepperpot
Maybe the HM130 max can cut a width of 30" but a HM130 can handle a 30" log but I think the Cant is 24" or under? The Logosol equivalent recommends the bigger Engine option if maxing out the Mill regularly with Hardwood which is 18hp. But if Im honest with the 14hp engine and Ripper Blades the 14hp does not really struggle till the Blade is dull altjhough I keep an eye out for the 18hp engine on ebay.
1 hour ago, topchippyles said:
IMG_20200926_181808519.thumb.jpg.59504586dde0fd2e5a6fa67bb63f9ccb.jpgIMG_20200926_181814217.thumb.jpg.3c3e09b6a377db87c0aa73cd421cc228.jpgOak porch i milled and built 4 years ago but i know nothing.All oak beams in photo came from the same tree.
Remember when you ripped those pictures off the internet and passed them off as yours on here and then  thanked people when they gave you praise for them?
I do, that was funny.
Maybe you should post more pictures of your work instead of constantly belittling other peoples work? That would be nice.
Edited by trigger_andy
The difference being you will notice a dull blade on a 14hp mill a lot sooner than on a more powerful mill. My electric LT20 could have had a 25hp petrol engine and that only had a max of around 60cm with the guards removed.
I think what I'm trying to say is that if you want to mill large slabs all the time its the same with most machinery. There is no replacement for displacement. Power is everything when it comes to milling large hardwoods or resawwing dried timber and if thats something the OP is thinking of doing thats my advice. The LT40 with the Diesel engine I used occasionally would chew through pretty much anything and wouldn't slow down but it was a bloody noisy thing.
