Hi All,
 Milling, for me, is a hobby.
Recently I've been gifted some large pieces and I've hit a small roadblock.
Q: I'm looking for an inexpensive way of moving slabs from my milling area to the air drying area.
The route is reasonably flat but the surface is road plannings with the odd  shallow-ish pothole. 25m ish run.
I work on my own and some of the slabs are 40kg -70kg.
Has anyone got some suggestions?  Budget ...like to be under £250 but can extend for the right kit.
Cheers
Bob
40-70kg is quite light really. Asmall 2 wheeled cart would handle that easily. Easy to make as well, just a couple of Trailer wheels, an axle and a sheet of Ply etc on the top. I have something similar I got for nothing that carts my beams around with ease.
20 minutes ago, se7enthdevil said:
how big are the slabs???
an industrial sack truck might do if they are not too long...
2.5m x 70cm x 50mm give or take.... Oak,
Like a Carpet dolly/cart I get it.
Yes the 40kg ones are manageable...but these are just a bit too much. Closer 70kg. I'm not a big chap...around 70kg myself.
a good sturdy sack truck with large wheels will do that.
i've strapped 8'+ boards to the truck and just hold the end of the board to wheel it around before now.
15 minutes ago, Will C said:
Look up “piano moving dolly” there excellent for moving all sorts of stuff
I have a couple of dolly's in the garage. They aren't much good on loose gravel. Many thanks though.
Bob
We always used a wheelbarrow for shifting planks, takes a bit of practice but balance the planks across the top and you'll be able to move them over almost any terrain.
