Hi All,
 To explain. Up until now I've milled green Oak and some dead(ish)ash. No problemo.
I've got a Stihl 10deg ripping chain and a granberg and I try to be very careful to get it set right.
To the point.. Today i was trying to mill a bit of fresh-ish Pine. About 10ft by 20 inches or so.
My first cut took nearly 3 tanks of fuel in the 660 whereas last year a similar chunk of Oak would take one tank per pass. the saw isn't struggling but I'm producing nowhere the amount of dust I'd expect.
So...Do I need to use a different angle?
Have I done something else wrong? Suggestions please. I've got several lumps to  do and I can't be doing 3 tanks a board.
Cheers Bob
When did you last clean the air filter? My 560 was bogging down today, got it on the bench and the air fiter was choked.
21 minutes ago, Bob_z_l said:
Hi All,
Cheers Bob
You say " dust " . I don't mill but have always associated " dust " with a blunt chain .
26 minutes ago, Rough Hewn said:
It's your depth gauges probably.
Without reducing those in line with tooth length, you will cut flour and push harder.
Cheers @Rough Hewn  I'll give them another check, I did suspect but wasn't sure.. It def isn't  a new chain
I hope not...I've cleaned and checked everything during my lockdown/furlough. Thanks @jfc I will give t another blast.
@Stubby Cheers...my observations with the ripping chain are that it does produce fine chip like a dust or powder.  Not like the lovely fat chips off the fresh crosscutting chains. If that makes  sense.
many thanks for the help and re-assurance.
Bob
The depth gauges, have to be lower than the std depth setting,, but not to low  so it grabs and Boggs. what was it rough?..30thou ?
my 660 I had to hold it back when the teeth were sharp ?
edit,,you want something like bran coming out
Edited by Wonky
Ed
my 660 I had to hold it back when the teeth were sharp [emoji1]
A tenth of a millimetre can make a big difference.
I go about 0.7mm - 0.8/0.9mm depending on species and width of cut.
Wider cuts higher gauges,
Fresh soft woods and under 1m drop the gauges to 0.8-0.9mm
(With an 880. Don't try this with a 660!)
Stick with 0.65-0.7mm with 90cc
[emoji106]
Thanks for all of this.
I wondered initially if there might be a difference between milling hardwood and softwood.
This is the first bit of softwood to have a play with.
Hopefully when it gets a bit cooler after 16.00.
Thanks  Bob
