5 minutes ago, Matt2110 said:
Has anyone get any idea where I can get 325 sprocket for a Husqvarna 61 if they do manufacture them or not?
Thanks!
Is the 61 large spline or small spline ?  If its small then any dealer I would have thought .
9 minutes ago, woody paul said:
Only can be done with rim sprocket.
Ah , yes . I was presuming it was a floating rim  when I made my reply .
Edited by Stubby
.325 on a 61 why? it had a 3/8 spur sprocket as standard, the rim sprocket will fit from the 266 you then need to get a .325 rim with the large spline, good luck with that.
