1 hour ago, trigger_andy said:
Now thats another brilliant idea! I have a mate that keeps a few Saddle Backs and sells the Pigglets off each time they are up the spout. I bought a couple last year for a Spit Roast, was amazing!
A Couple of them rooting around will soon have the ground nicely churned over! They seem to be a right bugger for escaping though.
I hope you bought them for a hog roast??
Have Pasquali XB40 - bought from eBay 8+ years ago.  Has a Yanmar Diesel engine and electric start.
As I understand it - this, Camon and Goldoni are all essentially made in the same factory - or to the same spec.
I have the rotovator and a rotary plough as attachments.  The rotovator will tackle most ground - but prefers something that has had some work in the past.  As others have said - it will leave a 'pan' so you may end up with drainage issues.
The rotary plough will tackle virgin ground.  In - fact - it seems to relish it!  Compared to the rotovator it cultivates a much narrower strip of land at each pass - but goes much deeper.
The XB40 is a pretty versatile machine [also have a flail and trailer].  It's very strong.  A couple of years ago, ran over some 10mm stranded fencing cable and although it got wrapped around the flail - did no damage at all.
Thanks for the heads up and info. :) More food for thought!
Virgin ground is definitely what I'll be needing worked at some point. Looks like I'll have to maybe increase my budget! :D
Just now, waterbuoy said:
Hire in a larger unit to break the ground and then use a smaller machine in years to come.  Simples.......
Good point!
Ive not ploughed any virgin territory in years! :D
1 hour ago, Conor Wright said:
Careful now, sounds like you'll end up spending your money on a hoe instead!
I hear the dutch ones are good...
Another thing on my 'to-buy' list is a Trencher. I really like laying Pipe and I think it would make this much easier to attain.
