15 minutes ago, Derek Eames said:
Gents
Would you walk past this tree?!? I usually walk on the opposite side of the road!
We have had some serious wind and rain this year .  Have you seen an increase in the lean over a period of time ?  If not It might stay like this for a few years yet . Does the crown look healthy ?
Would really need to see a pic of the stem at ground level and the area surrounding it along with the upper half of the canopy to make a proper judgement. It's a big lean but it may have many years left if its healthy.
On balance, crossing the road to avoid the tree may be more dangerous than walking below the tree!
  • Like 6
Why not ask if you can put a plumb line point and ground marker in, just an ally nail in the tree will do. I've done that a  few times following survey work and used the plumb line subsequently to establish nothing is moving.
Tree seems healthy and looks to be compensating for its lean, to a point. I'd regard it as being at higher risk of it failing in waterlogged/wet conditions and/or high winds.
A site visit would be required to properly assess the tree, if its your tree I'd recommend you getting a local tree care company to survey it.
Thanks all. Its not my tree (thankfully). Its actually local council (it even has a tree tag). The prevailing wind is directly across it so pressure on stem and roots must be enormous. A good example for Claus Mattheck...
More chance of winning the lottery than being crushed by that.  K
Edited by Khriss
( Obvs don't walk under it AFTER winning the lottery... or that would just be tempting fate.......
3 hours ago, Derek Eames said:
Gents
Walk under it? Perhaps not in a howling gale, otherwise, meh! why ever not!
