Seem to be getting myself confused. Looking for Husqvarna file guide or combination file guides for the following Oregon chain:
95txl 0.50 (1.3mm) gauge & .325 pitch micro-chisel narrow kerf
72dpx 0.50 (1.3mm) gauge & 3/8 pitch semi-chisel
Advice gratefully received!
Thanks Chris
Could never get on with those roller thingys.
found the stihl/pferd multi ones good but they get a bit loose and giddy after a while. Also one for each file size run into a nice few quid.
The old flat guides are as good as any, cheap and last forever.
Edited by s o c
Spelling
I have to disagree, the roller guides when used correctly are are very good, quick and a good final finish.
, they have to used correctly, the instruction on the packs i must admit are not very good, but once shown you never go back.
Had better luck just not using file guides but only tried the flat ones didn't realize the roller ones existed.
Ins't SPG33 the eqivalent as  95TXL so that might be the one to try?
Thanks Chris
Expand
I'm stating the obvious here,,, you know you need two different (edit: size ) files and guides for those chains..??
just makin sure ?
Edited by Wonky
Size
.325 is normally 4.8 mm file and respectively the file guide for that size file
and 3\8 lopro / picco. (Ie not std 3\8) is 4mm size file and the correct guide.
Edit.  Flat file is the same file for the rakers/ depth gauge
Can someone correct me or confirm this please..  as I know there is a bit of I know better with some folks like bucking billy... and tho odd little bits at the end of a tooth to help put the hook back on the tooth.?
Edited by Wonky
Edit
I jumped in wrong, the 72dpx is the std 3\8 and a 5.5 file
and not the 3/8 lopro
but you can see from the page/screenshot (chainsawbars brochure)
Thanks for the input guys, and charts, I have the correct files (4.8 & 5.5mm), it's just finding the correct Husqvarna roller guide reference as they are referenced to Husqvarna chain. I think whether it micro, semi or full chisel grind also makes a difference to which guide. Still a bit muddled!
Read more
