10 minutes ago, MattyF said:
Does any one know what it attaches too in the trigger end ?? A photo would be great!
Hooks into the actual trigger itself IIRC. There's two pins that go through the handle you need to drift out, then the whole trigger mech will drop out.
I’ll try pictures in a bit, I’ve just popped the safety trigger out the top for now. Looks like the end of the cable ( inner cable) located in the underside of the white plastic cam mechanism that pivots at the top pin in the rear handle. Hope that makes sense. The end of the outer cable locates in the front of the trigger
4 hours ago, MattyF said:
Awesome thanks ty ... got it located now , I hope your not having as much bother as me trying to get the dead mans back on!
No worries,I got mine back together ok.
