Hi All
Looking to remove the gloss/lacquer type finish that’s on an old anschutz 1427, had this thing for 21 yrs now and have always meant to get round to sorting the stock. Looking for the best option to remove the existing coating  and any ideas on best oil finish for the stock afterward. It’s not a showpiece and gets used regularly in the field.
cheers
22 minutes ago, Johnsond said:
Hi All
cheers
OK this is write up my street, If it was me i have a pot sand blaster here which i would have used to clean it back to bare wood, Other option is to gently wire wool it or use a fine sand paper. Apply 3 coats of fiddes rugger brown wax and use a polishing brush to buffer it each coat, Then i would apply 2 coats yacht varnish to harden for every day use
Fiddes Supreme Rugger Brown Furniture Wax Polish ...
Clear Yacht Varnish Spray Exterior Interior Waterproof 250ml
Edited by topchippyles
Cheers Les
Hoping to try and replicate the finish I had on a Tikka M595 super deluxe, it had mat oiled type finish no shine at all. , beautiful bit of wood, I’ve regretted selling it many a time.
Goggle fiddes and you will get a shade close to what your looking for And could use a matt finish which will not give a shine,Other than that an oil based finish applied with a rag,Link below and they will have what your looking for, All made in their own workshops in cardiff and sold worldwide,   (Bootiful) as  bernard  Mathews used to say about his turkeys ?
FIDDES - FOR BEAUTIFUL WOOD
? Cheers Les
Ok, when I did a HW80 stock I scraped the old varnish off, sealed the wood with a varnish heavily diluted with white spirits so it filled the pores but did not sit on the surface. Then I made my own rub-in stain with white spirits and burned umber artists paint which I applied as really thin washes til I  got to the colour I needed and finally oiled it and waxed it.  The stock is probably beech, so you could get hold of a piece and practice 1st
I use " Red oil " you put it on with a cloth and then " palm " it to get some heat into it . ( All this of course after removing original coating ) .  No need for any varnish .
Can i borrow your gun to shoot eggs and trigger and they are at it again (lovers tiff) :bash:
Quote 1 so far today and only early  (Back in ya box) trigger
Will keep updated work in progress ?
11 hours ago, Johnsond said:
Cheers Les
First centre fire rifle I bought was a Tikka M55 (if I recall) in 270 Win. That was 1981. Cracking rifle, floating barrel, never let me down. I started on 150 grain but changed to 130, but found them too hot. A friend of mine supplied home loads, back to150 but used a slower powder. Used on Sika , found that they weren't doing the same damage to the carcass as shop bought, in this case Norma. Changed over eventually to a 243 which did the job.
I would have cleaned it back with my sand blaster very gently using sharp sand instead of grit as a lot softer and never damages old wood if done correctly, Light sanding and ready to apply finish.
