Sthil 026 won't start help please
Dazonit
Hi all I'm after a bit of advice not used my 026 for a while got it out today it started but run rough tried to retune it and now it wot run and after trying to start it there is a noise like its sucking air.
It seems to be getting furl
Fitted a new carb kit last year and it started and run fine.
Were do I start
Cheers
The basics are spark, fuel and compression. Spark - earth it on top of the cylinder and pull over the saw hard, it should be a nice fat spark.
After trying to start it, the plug should be damp - if it isn't, it will most likely be the carb.
Compression - can you feel good compression on the starter handle?
It is possible that you didn't set the metering arm on the new carb kit and it now isn't letting in fuel (dry plug) or holding the needle valve open and flooding the engine (wet plug).
It is most likely a fuel problem if it ran fine on the last outing and went away running.
All petrol engines suck air - it is the way they work!
Ill change the fuel ishould of done that strieght away dam.
Tried fuel in pot no luck as I think its flooding so I'll change fuel and needle in carb .sthil not sure about fuel pipes as of the drawing noise not sure if it's drawing air
