I've recently had it where my battery was showing 12.2v so down a little but wouldn't do anything ... even when charged. Voltage was there but nobody (cracking amps) was home
So try jump starting before delving any deeper, we've all had it even on tractor batteries.
Even when the battery conditioners say it's good, come to crank and nothing especially on start stop equipment like chippers, forklifts etc.
Best thing I ever did was fit battery monitors/balance charger sockets, flashing green light or amber and it's time for a charge or a heavy bit of use.
Yeah when jump started and forced to recharge a 14.4 very etc they seem to do OK  when run for the day etc.... soon when left a week or so won't crank. I've one machine that doesn't get used often, I jump started it and left it running on trailer to site lol 😆  it ran all day then and was fine. But that was not last week, week before, bet it's back to knackered now.
No point fancying around though with batteries just swap them out.
On machines that don't get loads of use, unhook terminals and charge every now and again. Also make sure sat on a rubber matt etc.
My teleporter at yard I tried to wrap allsorts around it to keep frost out and touch wood that's fine.
On the chipper front as I've a few and swap between what I use each day / week I've decided not to renew battery on machine left idle but just pinch it off the one in use for the time needed
Always bought quality too... varta etc  not cheap shite
Edited by swinny
Yeap, was just saying start simple to identify the problem instead of thinking automatically it's something more in-depth 🙂
Yup, multi meter straight away. See if it will jump, if it does, multimeter again can tell you alot straight away 👍
