brand new t535/536li switched to 1/4" 10" pruning bar and chain (husky)  Chain leaves really ragged pruning cut and sometimes slips along the branch when starting the cut. tbh its rather crap. Any thoughts as to why??
Try one of these and compare - if you put up a video on here showing one set up cutting.... pros and cons, then switch to the Panther Mini and chain - show this cutting - we'll refund half the price back to you [make sure you PM me after you have done so]. This offer only applies to OP unless you post a particularly good vid in which case it applies to you as well...
The 3/8 lo pro and 1/4 .050 will never cut as smoothly as the super thin 1/4 .043...
WWW.CHAINSAWBARS.CO.UK
3 hours ago, billpierce said:
Is it .043 or .050 chain?
0.050
going to switch to a .043
though when i first tested the husky it was on 3/8  0.043 12" standard nose and it too was gash hence why we tried the switch to 1/4" and dime tip bars.
Made this stunner of a vid rob!
Probably not the best ad for the panther bars, doesnt really show a massive speed improvement, but it is definately a much finer cut on the 1/4 043 compared to the 3/8 043
That's not bad at all Bill and shows the control you get with the Panther Mini Bars - I sent you £15-00 thanks for posting.. image.png.6680defc8d3813b4424ff38803be6d90.png
Extraordinarily generous of you rob!
Great little bars
