Echo 2511 chain size help please
TreeAbility
I'm struggling to find Echo chains. I need to know how many drive links the 10 inch bar has? It's 043 1/4 inch but not sure drive links. Panther bar is 56 drive links but this is the echo bar which is a different shape. 10 inch Stihl 150 has 57 drive links.
Help please ?
Have you tried Rob D at chainsawbars.co.uk on this forum?
It should be stamped on the bar but if it's the newish style 1/4 cs2511 it should be 60 drive links. You will either need the tiny sugihara chain or get a ms150 chain made up. Just make sure it is the .43 gauge as if it's a .50 it all be the oregon 91 px/Vxl  chain.
The last batch of cs2511 we received had reverted back to the.50 gauge for some reason!
  • Confused 1
