Mine ended up in bits after a tantrum whilst trying to give up smoking , dealing with two ropes so had to order another from sky lands on Friday.
My practise with climbing saws always has been if its is over a year old and won’t stay In tune for more than a tank of fuel they should be replaced as it’s probably leaking air from crank seals and on climbing saws that are bread and butter they are better as spares.
I had given this one three carb rebuilds over two years so it had its time.
One thing worth checking as I’ve found to be a problem on the 2511 is split fuel lines.. if it’s not that and the carbs all good bin it.
Expand
Blimey Matt, have you aged, I thought if it didn't work, you shouldn't stand underneath as the tool was likely to be thrown out of the tree:scared1:;)
I won't say anymore...HS86...damn...sorry!!!
the rubber intake boot beneath the carb. can get pulled out of it's location which i think means it will draw air and cause idling issues.
Expand
You're so rock and roll?
  On 20/01/2020 at 23:39, peatff said:
You're so rock and roll[emoji41]
Wish I was Pete Townsend me see... that saw had tested me and ended up with the fate of being more a basil fawtly tantrum than rock and roll suicide... il be trying nicotine patches next time.
Read more
