My Falteimer cubes took a direct hit from 14oz throw bag the other day breaking one of its internal fibreglass 'legs'. A bit annoying now that it won't stand up straight.
I have not had a close look yet but seeing if anyone has successfully replaced broken bit with new fibreglass rod on the side/corner. Might need some hand sewing action.
Amazing the little details that go into these Falteimer cubes. Have picked apart the sewing at the top to pull out the fibreglass rods - well at least one of the broken bits. There's a soft plastic bit on the end that I guess protects the canvas from sharper fibreglass.
Hey, please let me know if you find one as the same happened to mine ages ago. I have to stand with it between my legs to keep it open.
Whatever you do, don't let Kevin get a hold of that post!
He's just turned my innocent polite enquiry on another thread into a dirty joke.
I did wonder as I pressed send.....
3 hours ago, Steve Bullman said:
Are the falteimer cubes even still available?
I'd hope so! The quality Vs stein and other versions pays for itself. Mine are over ten years old!
Never had a leg break but are you could pick up a fiberglass rod of the same diameter. If not maybe worth contacting whoever makes them?
