Which do you use... Base Anchor or Canopy Anchor
Treespasser
29 members have voted
  1. 1. Base Anchor or Canopy Anchor
    • Base Anchor
      1
    • Canopy Anchor
      8
    • Both... depending on the job specification
      20
Hi all,
Just created a quick poll (apologies if this has been discussed before, I'm sure it has) to find out how many of you use either anchor with SRT.
Reasons why you use your choice of anchor would be greatly appreciated.
Or does it ultimately boil down to what the job at hand is?
Many thanks
Saw this the other day and it was a timely reminder just how vulnerable you are on a Basel anchor-
There is too many factors that can cause a base anchor to fail- falling branches, sharp items on the anchor point, increased risk of the anchor point in the canopy failing, inexperienced ground staff damaging the base anchor.......
  • 4 weeks later...
  • 1 month later...
On 22/12/2019 at 14:50, Jake Andrews said:
I base tie for ascent then generally switch to a canopy tie for working.
What method do you guys use to switch to a canopy tie when in the trees? I can see it being a massive faff when trying to set it up. I'd like to get used to the last method in the Climbing Arborist - Canopy Ties video on Youtube, using a DIY cambium saver of sorts, to be able to ascend the anchor as well.
