Twin line working on “SRT”
I have been thinking about this twin line work position thing for a week or so and have had a couple of climbs on this system. I am looking for some feed back and to see people’s thoughts. I have found it to be not that bad at all in relation to having one line a pantin and a has. With two foot ascenders you can easily walk up the line and you don’t need a wrench because your weight is spread across the two lines.
A couple of points, it’s 10.5 static line so I understand the issues there and the carabiner I am using to keep the lines together is technically cross loaded as well but looking past that has anyone anything to add? IMG_6853.thumb.jpg.1f2b035038cce83d743c12fd84f53f62.jpgIMG_6855.thumb.jpg.f6151825f99f48b7f9d07ad6eb929556.jpgIMG_6857.thumb.jpg.7ee18ee7ed1c07ecdbea81a060afa832.jpgIMG_6851.thumb.jpg.81466fee513fcdc21b4855d9eba43005.jpgIMG_6858.thumb.jpg.b51196187984268b0bf4f87a6cb3f981.jpgIMG_6859.thumb.jpg.48566bc43fe057aca99a72a7845847e9.jpg
  • Confused 1
I can’t think how to make it simpler to be honest.
Yes, I was dismantling the tree, the last photo was how I configured the system to top out the tree, and descend to fell the pole. All the others were it set up “SRT” I am not really sure it can be simpler. It’s all on one instead of having two completely separate systems and lines etc
I think, in all honesty, the problem I am working on is if the HSE decide to hold fast to their decision then I want a system to be compliant so that even if the worst happens my family will be seen right from my insurance company and they can’t wriggle!
  • 4 weeks later...
A massive advantage of SRT for me has been the easy setting of high anchors.
This takes that straight out of the game.
I appreciate your sentiment, like, but I’ll stick to using two lines for jobs when it helps me.
Yeah, you can tie it in double after accessing singly with a wrench but it’s a faf. I have found myself reaching back for the old HTP and wrench to be honest.
Do you isolate your tip after accessing with a base? I do almost every time now after having a little accident in a pollard with my base tied line. I cut right through it sneakily hiding in an awkward knuckle... thankfully I was side stropped in.
The one thing I do like about the double line is instead of having one foot ascender and a hass you can have two foot ascenders it’s kinder to my knees as it seems to even out the loading. Maybe that just a me thing though. I think I will use it more on big trees but for day to day I have gone back to the tried and tested.
