Will  other grease do for a hedge trimmer gearbox instead of the overpriced Stihl Grease £10 for 80g?
From previous arbtalk threads people mention  a lithium EP2 grease?
WWW.AMAZON.CO.UK
Buy Carlube XGE500 Lithium Grease at Amazon UK. Free delivery on eligible orders.
Being using weldite "cycling grease" on strimmer head for yrs but unsure about just using any lithuim grease  for trimmer gearbox when stihl are selling there special grease....
WWW.AMAZON.CO.UK
Shop Weldtite Grease Tube 40g. Free delivery and returns on all eligible orders.
Best to go heavy on the grease. It tends to emulsify and collect above and below the gears, but not on them. I usually give them a good half dozen pumps every month, it'll only work its way out past the plastic seals, you can't do any damage.
On the long reach machines the grease port that does the angle adjustment doesn't need that much.
5 minutes ago, spudulike said:
The Stihl spec is to re-grease every 25hrs, not sure too many actually do this and the next step is to work out that a set of gears is ££££££££:scared1::cursing:
I grease mine before a hard day's trimming... 6-7 pumps of grease in the main body. You can still hear it getting clackety later in the day
