Got to ask, why would you go to the expense of this on most chippers when there are enough used ones available and every supplier/manufacturer would supply a new one?
Fair play for them to consider the engineering involved but it is a tad fussy trying to convert a road tow to off road. Everything has a place in the market and good look to these entrepreneurial engineers!
Seen that crop up on eBay when searching for used equipment. On one hand if you have a chipper sat in the yard that owes nothing and can be turned into a useful tracked unit for under 4k you think that's no *so bad*. But on the other you would just be better off selling your road tow and putting that 4k into buying a used tracked unit.
Or just buy a quad or compact tractor to take it wherever you need.
I wonder what it weighs? I use a small gravity fed chipper which uses 300kg of my payload leaving plenty for chip and wood. Wouldn't want a heavy tracked chipper but sometimes a roller feed would be good, this might just do it.
