Hi,
In general does the bolt securing the sprocket / clutch  on a chainsaw ( in this case old  Makita DCS6000i ) have a  right hand thread or is it a left hand ( like the drive side end  of a bike bottom bracket ). I need to change the sprocket which is pretty tight on and just want to make sure I am applying force in the correct direction ......
Edited by Scuttlefish
more detail
Hi,
It is not a bolt, the end of the crankshaft is threaded and the clutch is like a huge nut. The thread is set so that it tightens as the saw cuts rather than undoing, so has to be left hand.
Have you found just a sprocket or do you have a new drum as well? Changed the rim sprocket on my PS6000i but the drum will want doing next time and I think they are obsolete.
Most sprockets spin off clockwise (left hand thread) unless there is a separate securing nut but this is generally found on vintage saws only.
If you can't shift it - Use a big air impact driver - it will shift it PDQ.
2 minutes ago, adw said:
Just a short sharp blast with the impact gun, too much and it is possible to shear the flywheel key, i speak from experience.
Got that t-shirt as well, cept mine was cast into flywheel so new flywheel req
Looks like the clutch for dcs6000/6800 is obsolete but the drum is still available. .... didn't look too hard, part shop direct.co.uk  Had me worried there.
