Anyone any experience painting aluminium panels before signwriting?
Can you cheaply apply and get an OK finish, that the signwriting will stick too.
We have in the past attached boards or direct wrapping..
As Khriss says.....
It's the same as Landrover Panels...etch primer chemically bonds to the aluminium so that paint can then bond to the primer. If you don't regular paint just peels off.
Edited by Bob_z_l
spelling
As Bob_z_l and others have said, you need etch primer. The surface of aluminium quickly oxidises to produce a surface to which paint won't adhere. In olden-times they wire brushed the surface to remove oxides and then painted it quickly before more could form.
You must use an air-fed mask, especially when spraying 2-pack etch primer. If it contains iso-cyanate, the clue is in the last part of the name! Etch primer contains an acid which (naturally enough!) etches into the surface of the aluminium, allowing paint to 'stick'.
You can buy brush-paintable etch primer but you surely wouldn't have a surface that was smooth enough for sign-writing, would you?
I'm the author of: https://www.amazon.co.uk/Classic-Bodywork-Manual-step-step/dp/1899238336/ref=asap_bc?ie=UTF8
>>>ALSO I want to hire a firewood processor and operator within reach of woodland at WR6 6JG. Any suggestions? I may consider buying a processor at the right price.
Many thanks, Lindsay Porter
PS I really like being a 'junior' member. I'm 70 in a few days' time so that made my day :)
Edited by [email protected]
replies need enabling
2 hours ago, alfieb2785 said:
You will need to sand down to etch the surface I sprayed mine even in a hard frost but I but have a small fire going in the back to heat the metal and painted stuck fine
Cheers, it looks like you have had sign writing printed onto boards still. I was hoping to sign write directly onto the sides...
Edited by benedmonds
6 minutes ago, benedmonds said:
Cheers, but you have had sign writing printed onto boards still. I was hoping to sign write directly onto the sides...
Looks directly on the sides to me ... Could be wrong . ( often am ) ?
