how often do you change a sprocket
48 members have voted
  1. 1. how often do you change a sprocket
this is dodgy. if your using a saw up a tree the chain will last alot longer then on the ground as theres less chance of it hitting the ground, stones, nails... so the top handles sprocket would get alot more wear for 3 chains then a ground saw.
I will go along with that:top:
  • Replies 38
Every 2-3 chains - or, refer to the manufacturers instructions as to depth of wear on the sprocket concerned is the correct answer!
close but not corect sorry
3 chains to one sprog. the bar i only change if showing excessive wear blueing cracking or just worn to much.
This is a good rule as it keeps the engine under less stress using old chains and bars puts more stress on the engine.
I only just replaced my first chain on my newest top handel its over a year old and the chain was still good.
but i totally understand why guys use them to death they aint cheap.:girl:
3 chains and running them all in conjunction so that tehy all wear at approximatly the smae speed.
in reality, when its shagged
Jamie
