BEWARE If you see a wire going through a tree with yellow stripes orange markings on clamps no thicker that wire going to your house.
THIS IS A FIBRE OPTIC,Could carry 4 or 12 fibre's
If it has blue markings on clamps slightly thicker cable (36 fibres)
These normally feed businesses if you cut these BT may try passing any money lost by the customer on to you.
Poles should be marked up with yellow labels with (Fibre Optic)
So take extreme care.
BT also has a system were if a large copper cable is cut it measures the distance to the faults.
This system was put in place a few years ago when they were getting hit by cable thefts.
So the police may tip up before BT
  • Replies 62
Perhaps I'm out of line but if you cut through a cable or break one, consider it could be your fault,
Ansd something you have to take responsibility for.
