It only becomes pointless with unrealistic expectations.
If you wish to remove the usual bramble etc and anything up to about 4”, or just have a good old clear up at the end of a job you’ll be fine.
I recently worked with a 6 tonne JCB which had a Lipa Flail on, which I know has had an awful lot of hard use with no issues.
I was impressed with it’s performance for a swinging hammer flail, but once I took a look at the actual flails I could see why, as they were absolute monsters!
Guys are having great success with the Femac units, Osma from Exac-One have always been good.
FAE if you want to spend that sort of money, simply loads of choice.
Best advice is borrow/hire one before you purchase to see if it’ll do what you require?
Eddie.
1 hour ago, Stephen Blair said:
I use a flail on my 3 tonner, it will do 4” stems but best to leave those bits for the lads with the saw.
Which flail is that Stephen? And what does it get through ‘comfortably’?
