1 hour ago, openspaceman said:
What's the difference between a brushless and a digital brushless motor?
About £100 I bet. It will be going to Dyson probably.
As far as I'm aware, 'digital motor' is a marketing term invented by Dyson. All brushless motors are electronically controlled. There's a good explanation here https://en.wikipedia.org/wiki/Brushless_DC_electric_motor
On the other points, unless a motor uses superconducters (which require liquid nitrogen cooling) then they will never be 100% efficient, and the losses will be through heat due to resistance in the windings. When I'm not in the woods my day job is in renewable energy, and I previously worked in electronic engineering, so I do have some experience in this.
Digital motors have no windings they use magnets so removing the heating element, they are generators in reverse if they are spun without power they create electricity, the best are single phase running as three phase. They do however require a board to run simply wiring up to the current won’t work they just stay still.
Edited by dumper
Grammar
Sorry, all motors have windings (or coils). It's the flow of current through these that generates the fluctuating magnetic fields that 'push' against the fixed fields of the permanent magnets in a brushless motor. The electronics are to sense the rotor position, back emf, etc. and switch the current in the windings to make the rotor spin.
If you're sure you've found something different, please post a link to some technical details. Just saying it exists isn't enough I'm afraid.
Edited by MikePepler
Correction
Great
Perhaps one day we can have a separate discussion about personal renewable energy on another thread?
Just now, openspaceman said:
Great
Certainly, feel free to start one and tag me in it. ?
On 14/03/2019 at 11:06, Stubby said:
Send it to Spud for a rebuild and port job then sell the other as a working saw . They are saught after , being non AT and the last of the 3 series saws .
This is the best advice you'll get
