The pulley saver would be different to your current fixed ring set up.I use a ART rope guide which is brilliant and would be worth considering also. I've not tried the multi saver but looking at it I would imagine it would feel similar to your treehog to climb on but someone else might have other opinions.
I believe it also depends if you are on hitch or zigzag - some friction up top isn't a bad thing if you are using a hitch, as it takes some of the load off the hitch and reduces tendency to bind. Pulley and zz is apparently great combination but I have not climbed it.
The multisaver is a lot more useful than plain cambium saver, that is what I would buy but I am on a hitchclimber.
I use a distal hitch with a dmm triple attachment pulley. Iv tried the zz but prefer a hitch tbh. Iv looked at pros and cons of these two cambium savers and others aswel. I think il be going for the teufelberger multisaver as it’ll react the same as my current with the added bonus of adjustability and won’t put as much pressure on the hitch. Just needed as much advice as possible as these things ain’t cheap as you all know ?
