If the prussic will hold Pete' date=' I would have no qualms about using one ! :001_tongue:
A bit like sending a gun to be proofed.[/quote']
:001_tt2:
I'll let you know if it was ok.
If you dont hear from me, dont try it:sneaky2:
If i ever change carrer I want to be a crash test dummy:blushing:
  • Replies 31
Anyone got a picture of an adjustable cambium saver in action up a tree?? Ive never worked with anyone who has used one, so never seen how they work properly :blushing::confused1:
Or are they the same as the posh rope guide thingy you used to use Pete??
The 2 ring kind is different to the ropeguide.
With the 2 ring version, you simply adjust it down to the required length, then run the climbing line through both rings as normal.
With the ropeguide the pulley goes through the ring, then the rope runs on just the pulley.
Cheers Pete, Im with you now!! :thumbup1:
buy a ropeguide, southerners are so tight:sneaky2::lol:
Not tight Stevie, just thick:001_tt2:
Whats a ropeguide:confused1:
