Who can I ask to overhaul large thicknesser?
Squaredy
I have a large old thicknesser that I use quite a lot in my workshop and it is becoming noisy and it looks like it needs new gears and maybe bearings.
A new one is going to be around £15,000 which is out of the question and second hand is a bit unlikely as they do come up occasionally but they may well also need rebuilding.  I have spoken to DaltonsWadkin who can overhaul it for me, but I wondered if anyone had any other firm they could recommend for overhauling this type of woodworking machinery.  I don't think it is anything complicated that needs doing, but I think I would rather hand the machine over to a firm who have knowledge of woodworking machines, not just a general engineering firm.
There are plenty of machines available with a width of up to 2 feet, but this machine will plane 30 inches (750mm) and I do often use this width.  Suggestions very welcome.
Edited by Squaredy
Don't want to start another looming thread...
2 minutes ago, gobbypunk said:
Nice machine , is it 3phase as most seem to be sorry don’t know of anybody round my way maybe give Axminster Tools a call they might be able to point you in the right direction, I want one but don’t have 3phase
Yes it is 3 phase, and I also do not have three phase, but I run this off a genny.  Thanks for the suggestion re Axminster, but I think they are more on the light side rather than industrial.
There is a firm up in ross on wye that i have had dealings with before and also a guy down in llangorse brecon who over halls woodworking machines and i can get both numbers for you if it helps Squaredy.
Edited by topchippyles
I am upon the heads of the valleys so quite close so sure guys would be able to help.I have my own 3 phase machines and maintain them all and have just gone through my 3 phase sedgewick planer/thicknesser,Have you greased all the bearings and pulleys as that makes a huge difference.
Hi Topchippyles, thanks for your input.  Yes I would certainly like the contact details for the guys near Llangorse.  I know the two Steves at Ross, if it is Greenfields machinery - not sure they are up to the job of stripping down and rebuilding however.
