22 minutes ago, Stihl123 said:
I've stickered up, and there is plenty of airflow and I'll put the beech on top too
More airflow the quicker it dies and more likely to twist? Just thinking out loud. Im gonna be dropping some cherry soon and would like to Mill it. Saying that I milled it all at 1", maybe if I milled it at 2" I could save the middle 1"? :D
Let me know how it goes over the next few weeks.
Yeh just what I was told ref more airflow the better
But be good if one of the milling guys said their thoughts as best thing to do please?
Cheers
Edited by Stihl123
Yeh just what I was told rev more airflow the better
Cheers
Cheers
I dont think its a case of the more airflow the better. Its a balancing act and some seem to prefer thickier stickers than others. Maybe some prefer thicker or thinner sticks depending on what they are drying, but 1" seems to be banded about quite a lot. In the 3 years Ive been milling I find 3/4" a nice balance.
Cheers
How thick are the stickers and where have you stacked them to dry?
25x38mm roof batten i use
stacked in the little covered area made from pallet tops, so air flow all 4 sides and stacked off the ground obviously and a roof
if that makes sense!
2 hours ago, topchippyles said:
Put 5/6mm packers between each row and band strap them like i posted a couple of weeks ago
i've got the stuff for the plastic banding as well so that'll go round too :thumbup: thanks
Those battens are to thick, I wouldn't use anything thicker than 25mm, ideally 18mm and make sure it's the untreated roof battens otherwise it will mark the timber.
I dry all my timber in an open sided barn and to date after 15 years I've never had to band my timber to keep it flat unless it's softwood such as Larch
Edited by Forest2Furniture
ok cheers Patrick, will sort :thumbup:
