1 minute ago, Rough Hewn said:
Some great colour in those boards
Not a clue what they will end up being used for just can’t bring myself to chop it up for firewood ?‍♂️
[emoji23][emoji23][emoji23][emoji106]
Maxed out the 56" bar on the 60" panther mill yesterday cutting the big burr. Cut 6" off each side?
Or get out the 84" bar and set up the 80" panther mill....[emoji848]
Finally found a Saw and bar combo I can't lift...
No wounder you got a bad back with that ? is it your set up for a bit of high reach pruning ?????
Bet that’s a sickener to sharpen if you hit some metal etc.
  • Sad 1
Even a 48” chain is bad enough! I wonder if there is much extra teeth to sharpen on a chain that size of it’s a skip, or even a hyper skip chain?
I use the Granberg precision sharpener when out with the Alaskan. Saves a lot of time if you hit metal. Almost to the point that it’s quicker and easier sharpening a 48” chain than removing the saw from the mill and changing the chain over for a fresh one.
It's hyper skip. Think it's only got about 20 teeth.
The way forward ?
Jokes aside how do you rate that ??
