With all these Chinese Saw owners coming outta woodwork Roughy is gonna be throwing a fit. [emoji3]
[emoji848]
You’ve got to start somewhere.
But if you’re milling 30” boards you’re at the limit of that machine.
Just be aware the safety functions may not work as intended...
(Farmertec are actually made in a cheese factory in wushu province.)
(Ok I made that last sentence up).
Sell a load of boards and buy a proper saw.
Even a £100-200 old stihl 051/070/076 etc will be great for milling and much safer.
If anyone with a farmertec wants to try milling with an 881, and see the difference.
Get in touch, we could do a short video?
[emoji106]
And you said there would be no one on here with a Farmtec saw. ;) I know for a fact there’s more than letting on here. 😃
Putting your 881 up against anything other than a 881 copy would be utterly pointless. You’d be better off putting a stock OEM Saw up against a Farmtec saw and comparing the difference. But I think you know that and intentionally did not offer such a comparison as you’d most likely not see much.
Some of the lads knock a cheap saw but for someone who does not have the budget to buy a high end stihl or husky they are a good second option.I have a good saw but wold not think twice about getting another farnertec as a backup.
Yes true. I’ve looked about for big old saws too but not come across anything really at a reasonable price.
I think if you can respect your tools, keep them in good health, they will last.
And you said there would be no one on here with a Farmtec saw. [emoji6] I know for a fact there’s more than letting on here. [emoji2]
Should have said 661?
Literally the only things which annoy me about farmertec is :
A: it’s a badly made copy.
B: the safety features are dodgy at best.
Otherwise like I said it’s a start.
[emoji106]
There’s loads of videos of Farmtec 660’s running up against stihl 660’s. Again, it would be pointless running a Farmtec 661 against a Farmtec 660 for the obvious reason.
Out of the thousands of Farmtec users not many complain they are a badly made copy. They all seem very happy with them and have years of use out of them if treated with respect.
Not sure how much safety features come into play when milling. What safety features does an 070 have that will come into play when Milling? Yet you’re telling folk they should buy one of them instead. No chain brake and no anti-vibe.
Have you got one Andy?
[emoji6]
[emoji848]
[emoji106]
Mallof was an 090 man, how does that compare to the 881? Genuine question. [emoji106]
I certainly wouldn’t mind a 661 or an 881. It’s a shame husky haven’t come up with anything bigger in their stock. I suppose it’s on the cards and part of a different thread on here.
It’s about £1700 for a panther mill with the 881 from what I’ve figured. Potentially more. It’s something to work towards.
But the overriding point here is that milling is a brilliant way of using timber for something other than fire wood. [emoji106]
3 hours ago, AJStrees said:
Mallof was an 090 man, how does that compare to the 881? Genuine question. emoji106.png
That would be a very interesting comparison to run.
I will speculate.
Comparatively, the 881 has lower total power, lower torque and higher chain speed.
If I set up four logs side by side and squared off the edges, so they were absolutely uniform width along the length. Of those logs, I had 2off pine and 2off ash. One of each was 20" width and the other was 48" width.
If I ran the chains set up to book values on raker depth, I would expect the 881 to be faster in both the 20" logs and in the 40" pine. If I tried to push it hard in the ash it would start to bog down, so I would have to ease off to keep the cut running. It would do a nice job overall, but a bit slower. The 090 would just keep going and be faster overall in that log.
If I re-set the raker depth for each individual log, I would expect the 090 to be faster in all four, taking out huge chips in the softer wood, big chips in the 20" ash and standard chips in the 48" ash. However, if I had a mix of milling to do, I would have to keep swapping chains which would take away a lot of the advantage.
Will Malloff was mostly working with a single species so he had less variation needed.
The other thing an 090 will do is to keep chewing through the wood even when the chain isn't perfectly sharp. It is not advisable - the saw lets you know with vibration - but it will finish that last 6" of a cut to save dragging the saw back 20' much better than anything else will.
Alec
