I like that!  Couple questions:
Can you adjust cut length?
Whats max diameter stick?
Green wood and deadwood OK?
Who’s selling these in UK (petrol or hyd rather than PTO)
Reasonably priced?
Rather than chipping, what a great method of gaining pallets of ready cut small log. Like it ??
Edited by kevinjohnsonmbe
13 minutes ago, kevinjohnsonmbe said:
Quick search, found these http://www.welmacuk.co.uk/branch_loggers.htm
Will have a better look on PC later
Yes, that is who I bought it through but they are not up the site yet. Not an option on log length other than choosing the 3 knife or 4 knife option and the bigger machines do a longer log length. Greenwood is best but I was processing dry slightly turned beech in the video and yes well priced IMO. It's this firms machines sold through Welmac https://remetcnc.com/?lang=en
1 minute ago, Conor Wright said:
Nice. Similar to the gr110 I have but with a wider infeed chute and looks altogether a bit sturdier! Great, simple devices. Hope you have a slip clutch fitted!
No clutch just a shear pin on the PTO
Make sure it will shear before it cuts out the tractor, or worse. I made that mistake and stripped the drive cog on the pto.. was logging Hawthorn at the time. A v that was just a touch too big went in and immediatly jammed the blades The shearpin stayed intact. Was rated for heavier duty than the pto gearing on a compact tractor! It's on a clutch now. 35 hp tractor.
